Actual element not updating (2026.4.1.5)
Hello,
I am changing the selected surface area on the cad to change some sections and the actual sections are not updating.
I tried recalculating the project, changing aligments, restarting inspect and a couple more randoms stuff.
Anyone had this problem before and found a solution other than deleting and recreating the elements?
Hello Tim,
That is right.
So you are saying that this is intended behavior with the measurement principle "actual section"?
I was under the impression that a parametric software would also change the calculation when creating the actual section, when underlying parameters are changed.
I will have look into that, thank you.
