[Pe...] Posted July 1 Share Posted July 1 I really hate the recently used list. Mainly because it seems I need to wait another 4 months to be able to use it since I havent had a 10/28/26 yet. 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted July 1 Share Posted July 1 You can edit manually this file stored in your windows user profile - it's just a xml document Please sign in to view this quote. 2 Link to comment Share on other sites More sharing options...
[Lu...] Posted July 1 Share Posted July 1 Hi Perry, To clear this list, head to C:\Users\YOUR USERNAME\AppData\Local\ZEISS\CALYPSOFileDialog.exe. Find the file called "user.config". I would recommend renaming this file so it can serve as a backup. Then once you run CALYPSO it will generate a new user.config file. Hope this helps. 2 Link to comment Share on other sites More sharing options...
[Ke...] Posted July 1 Share Posted July 1 Please sign in to view this quote. I don't hate the recently used list... but I do hate that now I have to click two different buttons to look up a program 🤷♂️ 1 Link to comment Share on other sites More sharing options...
[Za...] Posted July 1 Share Posted July 1 If you want to remove only CERTAIN programs from the list: Close CALYPSO Navigate to C:\Users\<USERNAME>\AppData\Local\Zeiss\CALYPSOFileDialog.exe and open the user.config file with notepad++ or something similar. 3. Please pay close attention to the differently highlighted lines provided in the screenshot above. Lines 5-8 have a “0” in the key. lines 9-12 have a “1” in the key, so on and so forth. If i want to remove the “GDT Day 4 Ex 2” program, i would delete lines 9-12. 4. The Last step is to ensure that there are no skipped numbers in this file. For all lines below the program which was removed, fix the count to be in order. Using the screenshot above, if you deleted the “1” lines, you will have to go to the next program and change the 2 to a 1 to fill in the gap, and repeat for all later listings. 1 Link to comment Share on other sites More sharing options...
[No...] Posted July 2 Share Posted July 2 Why is it that despite a lot of convenient functions being added to Calypso, we still have to edit a config file in 90s style from time to time, only to achieve such a simple goal? In the 21st century a "Clear List" button really shouldn't be too much to ask for. 🙄 3 Link to comment Share on other sites More sharing options...
[Za...] Posted July 2 Share Posted July 2 Please sign in to view this quote. You make a good point. In fact, we'll be escalating this to the development team as a possible new feature in upcoming versions. 2 1 Link to comment Share on other sites More sharing options...
[No...] Posted Monday at 06:28 AM Share Posted Monday at 06:28 AM (edited) Great. 🙂 And while you're at it, I think there's enough room for another button: "Make list go away FOREVER" Ok, I'm kidding here - a bit. But not everybody is happy about this list. In my case I have several folders with programs on the network, each folder has identically named programs, but with slightly different content. Each of them is dedicated to a certain CMM. Now if I see a program in that recent list, I am unable to distinguish which version from which folder I'm looking at, so I might open the wrong one. That's why I always use the classic open file dialog anyway and would like to deactivate that list. I know how to do that, but it comes back after every update, so I stopped trying. Edited Monday at 06:30 AM 2 Link to comment Share on other sites More sharing options...
[Za...] Posted 7 hours ago Share Posted 7 hours ago (edited) Please sign in to view this quote. You can do that too! it's back to the "90's style tinkering" but if you close out CALYPSO, then navigate to C:\Program Files\Zeiss\CALYPSO 8.0\bin\CALYPSOFileDialog (or whichever calypso version you're using) there will be a CALYPSOFileDialog.exe. if you rename that executable to "testCALYPSOFileDialog.exe" or something similar, the next time you launch CALYPSO and click on Open Measurement Plan, then the windows file explorer will open, rather than the file dialog box. if I'm not mistaken, any time you upgrade to a new service pack, these steps will need to be re-conducted. Edited 7 hours ago 1 Link to comment Share on other sites More sharing options...
