[Pe...] Posted July 1 Share Posted July 1 I really hate the recently used list. Mainly because it seems I need to wait another 4 months to be able to use it since I havent had a 10/28/26 yet. 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted July 1 Share Posted July 1 You can edit manually this file stored in your windows user profile - it's just a xml document Please sign in to view this quote. 3 Link to comment Share on other sites More sharing options...
[Lu...] Posted July 1 Share Posted July 1 Hi Perry, To clear this list, head to C:\Users\YOUR USERNAME\AppData\Local\ZEISS\CALYPSOFileDialog.exe. Find the file called "user.config". I would recommend renaming this file so it can serve as a backup. Then once you run CALYPSO it will generate a new user.config file. Hope this helps. 2 Link to comment Share on other sites More sharing options...
[Ke...] Posted July 1 Share Posted July 1 Please sign in to view this quote. I don't hate the recently used list... but I do hate that now I have to click two different buttons to look up a program 🤷♂️ 2 Link to comment Share on other sites More sharing options...
[Za...] Posted July 1 Share Posted July 1 If you want to remove only CERTAIN programs from the list: Close CALYPSO Navigate to C:\Users\<USERNAME>\AppData\Local\Zeiss\CALYPSOFileDialog.exe and open the user.config file with notepad++ or something similar. 3. Please pay close attention to the differently highlighted lines provided in the screenshot above. Lines 5-8 have a “0” in the key. lines 9-12 have a “1” in the key, so on and so forth. If i want to remove the “GDT Day 4 Ex 2” program, i would delete lines 9-12. 4. The Last step is to ensure that there are no skipped numbers in this file. For all lines below the program which was removed, fix the count to be in order. Using the screenshot above, if you deleted the “1” lines, you will have to go to the next program and change the 2 to a 1 to fill in the gap, and repeat for all later listings. 1 Link to comment Share on other sites More sharing options...
[No...] Posted July 2 Share Posted July 2 Why is it that despite a lot of convenient functions being added to Calypso, we still have to edit a config file in 90s style from time to time, only to achieve such a simple goal? In the 21st century a "Clear List" button really shouldn't be too much to ask for. 🙄 3 1 Link to comment Share on other sites More sharing options...
[Za...] Posted July 2 Share Posted July 2 Please sign in to view this quote. You make a good point. In fact, we'll be escalating this to the development team as a possible new feature in upcoming versions. 3 1 Link to comment Share on other sites More sharing options...
[No...] Posted July 6 Share Posted July 6 (edited) Great. 🙂 And while you're at it, I think there's enough room for another button: "Make list go away FOREVER" Ok, I'm kidding here - a bit. But not everybody is happy about this list. In my case I have several folders with programs on the network, each folder has identically named programs, but with slightly different content. Each of them is dedicated to a certain CMM. Now if I see a program in that recent list, I am unable to distinguish which version from which folder I'm looking at, so I might open the wrong one. That's why I always use the classic open file dialog anyway and would like to deactivate that list. I know how to do that, but it comes back after every update, so I stopped trying. Edited July 6 2 Link to comment Share on other sites More sharing options...
[Za...] Posted Thursday at 04:14 PM Share Posted Thursday at 04:14 PM (edited) Please sign in to view this quote. You can do that too! it's back to the "90's style tinkering" but if you close out CALYPSO, then navigate to C:\Program Files\Zeiss\CALYPSO 8.0\bin\CALYPSOFileDialog (or whichever calypso version you're using) there will be a CALYPSOFileDialog.exe. if you rename that executable to "testCALYPSOFileDialog.exe" or something similar, the next time you launch CALYPSO and click on Open Measurement Plan, then the windows file explorer will open, rather than the file dialog box. if I'm not mistaken, any time you upgrade to a new service pack, these steps will need to be re-conducted. Edited Thursday at 04:29 PM 1 Link to comment Share on other sites More sharing options...
[No...] Posted yesterday at 06:36 AM Share Posted yesterday at 06:36 AM (edited) Please sign in to view this quote. That is exactly what I was talking about. I can make it go away (If I remember correctly, it's even possible to do it from the dialog window with the context menu). But with each new service pack or revision upgrade it comes back. I would prefer to make it go away for good. Or even better, to have a config option. Edited yesterday at 06:37 AM Link to comment Share on other sites More sharing options...
[Th...] Posted yesterday at 10:49 AM Share Posted yesterday at 10:49 AM On ZEISS's recommendation, I renamed the file "CALYPSOFileDialog.exe" because the official method of disabling this new menu caused extremely long loading times on my system. However, renaming the file has a downside, at least on both of my machines. The Windows Explorer now opens in the Workarea folder instead of the Inspections folder. This is also quite inconvenient. Link to comment Share on other sites More sharing options...
[Lu...] Posted 17 hours ago Share Posted 17 hours ago Hi Thomas, The path that CALYPSO opens when you click "Find" is set at Extras > Settings > Environment > Paths (Default Path for Measurement Plans). It is strange that renaming "CALYPSOFileDialog.exe" would open a different path than the one specified by the Default Path for Measurement Plans. Is the default path on your systems set to the Inspections folder? Link to comment Share on other sites More sharing options...
[Je...] Posted 16 hours ago Share Posted 16 hours ago (edited) Please sign in to view this quote. User Interface. It's Calypso's greatest weakness. The geometry wizards who designed and manage Calypso's architecture need to team up with an entirely different group to modernize Calypso's UI. My kids' Roblox games have more visually-fluent interface. Edited 16 hours ago Link to comment Share on other sites More sharing options...
[Th...] Posted 7 hours ago Share Posted 7 hours ago Please sign in to view this quote. Hi Lucas, Yes, the path is defined correctly. You can also see that because "Inspections" is selected at the bottom in the Filename field. The issue is that the Inspections folder itself should be opened in the Explorer window, rather than just appearing in the Filename field. Link to comment Share on other sites More sharing options...
