[Je...] Posted March 4, 2023 Share Posted March 4, 2023 Hello, I would like to modify the supplied CSV export filter to remove some unnecessary columns and adapt it for a specific application. When I export one of the existing filters I see that the file format is type .xslz. This appears to be a binary format and is not editable with a standard text editor. Is there capability within gom to edit these export filter definitions? When I look in Preferences->import/export->Export I see a list of available filters and at the bottom there is an option for "user" and the capability to import. Is there a way to create these .xslz definition files externally and then import? Link to comment Share on other sites More sharing options...
[Da...] Posted March 6, 2023 Share Posted March 6, 2023 Hello Jeff, xlsz is a double zipped file. So you can unzip it twice to get the xsl files. The easier way is to copy the format into the user space. Just Strg + C and and Strg + V the format in the preferences window. Then you can find the format in "\AppData\Roaming\GOM\2022\export\xslt". Here you can modify it. Greetings Daniel Link to comment Share on other sites More sharing options...
