[Ka...] Posted 11 hours ago Share Posted 11 hours ago Dear colleagues, As much of CALYPSO still dates back to the 1990s, when IT was simply a tool and usually worked, I’m hoping for the standard functionality of that era. Virtually every piece of software (even CATIA...) could be controlled or enhanced via environment variables. One example is the batch files, which still work well as user exits. Now I would like to trigger a user input via one of these batch files, *calculation_end.bat*. I would then like to use this input – for example, a name – as a log header variable in a PiWeb log. We do not have PCM, which is probably the biggest limitation for such functionality. So is there a way to get an environment variable into PiWeb somehow? e.g. Zaphod_Beeblebrox=42 as environment variable Best Regards Karsten Link to comment Share on other sites More sharing options...
[Ch...] Posted 7 hours ago Share Posted 7 hours ago I believe so by mapping header variables Here's a doc I stumbled upon .. https://qualityforum.zeiss.com/migration/images/267_af4856641ffdecd817e9e29ae54f4816.pdf 1 Link to comment Share on other sites More sharing options...
[Ab...] Posted 5 hours ago Share Posted 5 hours ago we have a Knowledge base article also on How to Customize the Standard Protocol Header https://portal.zeiss.com/knowledge-base?id=454780 Link to comment Share on other sites More sharing options...
