[Sv...] Posted July 14 Share Posted July 14 Hi Community. Is there a PCM command in witch I can get the status of an element or feature? I search for a query for a feature/element not can be calculated. (magenta one) Is there a way to check ? (maybe true or false) Best greetings Sven Link to comment Share on other sites More sharing options...
[Mi...] Posted 4 hours ago Share Posted 4 hours ago Should be possible with getActual(feature).error return value: 0 -> no error -5 -> 'Not enough points available for the feature calculation' (Every value characterizes a type of error as for instance -8 -> 'Error during iteration of the feature calculation') Link to comment Share on other sites More sharing options...
