DMIS Result Output
Good evening,
I am new to Calypso Zeiss.I am busy with dmis export of the measured points and i want to use a very specific header.Is it possible to modify header fields according to my needs.I mean i want that the header uses whatever fields i give.For example of one field
PR(1)=12345678
Thank you in advance.
https://qualityforum.zeiss.com/topic/27005-dmis-result-output/
