Decimal Based Tolerancing
Is there a way to run a .xml that can read the number of decimal places in the nominal and give the tolerance based off that value?
Example conditions below:
  • 3 place decimals: +/-.005
  • 2 place decimals: +/-.01
  • Angles: +/- 1.0
Is there a way to do this through a .xml or .tol file though?  I do not have a PCM license, and my production floor cannot run PCM.
Through tolerance selection it's not possible. You are defining only range of nominal and it will give you the tolerance, it's not reading how many decimals there are.
Only PCM or a parser of "inspection" file and do changes outside Calypso.
