Auto-Detect Cavity Numbers
Is there a way in ZEISS INSPECT for the software to automatically recognize the cavity ID of scanned parts and then sort accordingly? Ideally, I'd like to scan eight parts at once, have the software identify and arrange them by cavity number (1 through 8), and then generate a PDF report with the cavities listed in that order?
If you would use some sort of fixture with ref. points, then you can create a program where it will select box for each part.
Also there is an python app for OCR, you just select picture to read it - i have no success with this.
Yes, but not natively by cavity number. The most reliable method is to fixture the parts in known positions, use multipart scanning, and assign cavity IDs based on position. If the cavity number is physically marked on the part, a custom OCR/Python solution may be possible to automatically identify and sort them before generating the PDF report
