Rotate plane or line (GOM Inspect non PRO)
How to rotate existing line or plane. I would like to rotate existing plane by 90 degrees?
Is there any transformation tool, 3d gizmo or so?
Hello Marcin,.
You can rotate a plane on the construct menu (plane -> Rotate Plane)
Chose the rotation point (plane)
The normal
The axis (x/y/z)
And the angle that you want
And the plane will rotate to direction that you chose
