[Gá...] Posted July 24 Share Posted July 24 Hi the latest 8.0.3083.0.7f66405 update not avaible via Zeiss Download portal yet. I managed to install it when ZQS released it as an update. The new option to create a desktop shortcut is great, so you can now launch 2026 from the desktop. It would be nice if this option also appeared in KIOSK in Tools, so you could create a desktop shortcut from it. Link to comment https://qualityforum.zeiss.com/topic/27085-zeiss-quality-suite-update/ Share on other sites More sharing options...
[Na...] Posted July 24 Share Posted July 24 Hi Gábor, the kiosk shortcut will be created when the kiosk setup script is run. I think it's handled a bit differently, because there is no license configuration saved with the kiosk shortcut. Instead it starts the kiosk script with this line as a target. You could copy and paste it to another shortcut if you deleted the kiosk shortcut for example. "C:\Program Files\Zeiss\INSPECT\2026\bin\ZEISS_INSPECT.exe" -kiosk -fullscreen -eval "gom.script.userscript.KioskInterface__Start()" Nanno Link to comment https://qualityforum.zeiss.com/topic/27085-zeiss-quality-suite-update/#findComment-153417 Share on other sites More sharing options...
