[Nu...] Posted March 5, 2023 Share Posted March 5, 2023 Hi , I opened two Atos projects, then I initialized and calibrated the sensor on one side of the Scanbox, however, I had to measure the part on the other side because it became a priority. After inspecting the priority part, I closed the window of the scan box, and could not initialize the other side which I had initially initialized and calibrated. I had to exit and closed the program and copied a previous project to be able to do the inspection on the side. Kindly, explain what I did wrong and how to handle the situation if it occurs again. Thank you. Nurain Link to comment https://qualityforum.zeiss.com/topic/2709-moving-from-right-to-left-cell-of-the-scanbox/ Share on other sites More sharing options...
[Ma...] Posted April 28, 2023 Share Posted April 28, 2023 Hi, sorry for the late answer. It is hard to help on such questions in the forum. From your description I cannot determine want went wrong. If the same happens again, please contact your local support contact. Thank you. Regards Matthias Aalto Link to comment https://qualityforum.zeiss.com/topic/2709-moving-from-right-to-left-cell-of-the-scanbox/#findComment-7669 Share on other sites More sharing options...
