[Nu...] Posted March 5, 2023 Share Posted March 5, 2023 Hi , I opened two Atos projects, then I initialized and calibrated the sensor on one side of the Scanbox, however, I had to measure the part on the other side because it became a priority. After inspecting the priority part, I closed the window of the scan box, and could not initialize the other side which I had initially initialized and calibrated. I had to exit and closed the program and copied a previous project to be able to do the inspection on the side. Kindly, explain what I did wrong and how to handle the situation if it occurs again. Thank you. Nurain Link to comment Share on other sites More sharing options...
[Ma...] Posted April 28, 2023 Share Posted April 28, 2023 Hi, sorry for the late answer. It is hard to help on such questions in the forum. From your description I cannot determine want went wrong. If the same happens again, please contact your local support contact. Thank you. Regards Matthias Aalto Link to comment Share on other sites More sharing options...
