[Ka...] Posted 4 hours ago Share Posted 4 hours ago Hello experts, We have around 1,500 programmes, the majority of which run via Autorun. To display the workpiece positioning status, we use ‘CNC → Measurement Sequence Information for CNC start-up'. This does not link directly to an image, but rather to a small script that launches a simple and secure image viewer. For historical reasons, this is a *.bat command script that has many drawbacks. We would like to replace it with VB/Perl/Python... However, to do this, we would have to open more than 600 programes manually to change the link from XXX.bat to, for example, XXX.vb. This is not an option. Simply call from this *.bat script a VB script lead to open an terminal window ( one of the big drawbacks..) for up to seconds. This should be mainly suppressed. Is there a way to run this change as a batch job? The entries are contained in the inspection/inspset files.. Best Regards Karsten Link to comment Share on other sites More sharing options...
[Ma...] Posted 4 hours ago Share Posted 4 hours ago I can handle that, but i would need to know what to do - what changes you need? Link to comment Share on other sites More sharing options...
[Ch...] Posted 2 hours ago Share Posted 2 hours ago Please sign in to view this quote. you can make the VBS script run in a hidden window by using the "0" parameter. For example, I run a lot of .bat files but I want the terminal window hidden from operators, so I use something like this. Set WshShell = CreateObject("WScript.Shell") WshShell.Run "cmd.exe /c C:\Path\To\your_file.bat", 0, False Link to comment Share on other sites More sharing options...
[Da...] Posted 1 hour ago Share Posted 1 hour ago Notepad++ Search > Find in Files > Replace in Files Link to comment Share on other sites More sharing options...
[Ka...] Posted 1 hour ago Author Share Posted 1 hour ago Chad, Thanks for the tipp. I already use this but unfortunately the terminal window from calling Process ist still open because I have to wait until the image viewer is started to send via IPC a signal. Otherwise the window is not in focus. This take around 1-2 second´s and the terminal is still open this time. David, Thanks but I prefer to use vi 🙂 or in this face find, grep,awk ... The big question is: If I change the inspection/inspset files, will CALYPSO take account of it or is it ignored or more worse: Is running but use save program will overwrite the changed files with old values. Martin, Fine, but what do you use to do this? Link to comment Share on other sites More sharing options...
[Ma...] Posted 1 hour ago Share Posted 1 hour ago I would need what approach you want to go. Mass edit of inspection file changing ".bat" to another executable or another approach? I am using vbs script which hides batch window while having scheduled task. CreateObject("Wscript.Shell").Run """" & WScript.Arguments(0) & """", 0, False Using it like hidden.vbs do_work.bat Link to comment Share on other sites More sharing options...
