[La...] Posted July 30 Share Posted July 30 During troubleshooting when running a part, sometimes I will normalize a vector and I have noticed that when doing that it makes the A1 and A2 angle for the 3D feature check a perfect zero. I was curious if that is all it is or if there is more to it? Similarly, whenever I open up a position from the characteristic menu, I see there is a letter "P" and a bent line icon next to it and I was wondering what is the exact purpose of those? Link to comment Share on other sites More sharing options...
[Ma...] Posted July 30 Share Posted July 30 "P" will evaluate in nominal length of cylinder for example. Bended will evaluate on measured length. I am not sure what you mean by your correction of vectors. On points or on what or when and why you do it. Link to comment Share on other sites More sharing options...
[La...] Posted July 31 Author Share Posted July 31 Please sign in to view this quote. I'd say when and why. For example if I am checking a concentrcity and it is out tolerance, there are certain instances where checking normal vector within the datum feature will cause the concentricity to check better. Link to comment Share on other sites More sharing options...
[La...] Posted July 31 Author Share Posted July 31 Please sign in to view this quote. I also wanted to ask, whenever you press on the "P" you are able to change the measure reference length. Is changing the measured reference length similar to the "bended" function since you could change the reference length of your cylinder to only what was measured? Link to comment Share on other sites More sharing options...
[Ma...] Posted July 31 Share Posted July 31 Well ok, by normalization you are talking about restriction in feature's evaluation tab. It' just calculating measured data with fixed attribute ( restricted ). You can get more correct center of partial circle by forcing calculation with norminal radius. Same applies to A1,2. Using "P" usually means projected. In TP you can use that for projected tolerance. Link to comment Share on other sites More sharing options...
[No...] Posted August 24 Share Posted August 24 [smart ass mode on] Please note that in mathematics the term "normalizing a vector" usually means to give it a standard length (like 1). What you did is to constrain the vector (to its nominals). Using the term "normalize" here is quite misleading. [smart ass mode off] 1 Link to comment Share on other sites More sharing options...
