Filtering
Would like some insight from others on appropriate filtering and evaluation on a large diameter. I have set up this feature following the condensed cookbook guideline as a baseline.
Requirements: Looking for size, location and roundness of a ~7" OD. Assume part is in an as-machined state with a fairly tight tolerance on size.
Setup: Scanning using rotary table with Vast XT head, probing in X- axis, I believe it's a 3mm probe at the moment. Currently on Calypso 2023.
Strategy: Speed .591"/s, 5000 points, 380º, 500 UPR, 10-5000 pre-filter, ±5 adj points, 3 sigma.
Should these values be adjusted in any way and why?
Would these values need to be adjusted if the part were to be shot-peened and what would those settings look like?
Looking forward to learning from everyone. Thanks in advance!
