[Ra...] Posted Friday at 07:56 PM Share Posted Friday at 07:56 PM I'm curious if anyone has ever had getActual(char).toleranceState be flat out incorrect? I'm testing something offline, could it be because of that? Calypso 2025 Link to comment Share on other sites More sharing options...
[Ri...] Posted Saturday at 04:29 PM Share Posted Saturday at 04:29 PM Explain what you mean by wrong. Maybe show a snippet of your code. Link to comment Share on other sites More sharing options...
[Ra...] Posted Monday at 11:43 AM Author Share Posted Monday at 11:43 AM In the post settings of the characteristic. Link to comment Share on other sites More sharing options...
[Ra...] Posted Monday at 12:17 PM Author Share Posted Monday at 12:17 PM Edit: It seems like the calculation only occurs after an entire CNC run with clear existing results is checked. If you rerun just the feature or update the tolerance, the tolerance state does not update. If anyone happens to know the exact parameters of the triggering of the calculation, I'd really appreciate it. Link to comment Share on other sites More sharing options...
[Ra...] Posted Monday at 01:51 PM Author Share Posted Monday at 01:51 PM (edited) 2nd Edit: It actually seems to just be wrong sometimes, even when completing a new run. Maybe it bugs out when placing in the post settings of the characteristic in question? Edited Monday at 01:53 PM Link to comment Share on other sites More sharing options...
[Ri...] Posted 3 hours ago Share Posted 3 hours ago For gits and shiggles, place the same code in a Result Element and see if it is correct all the time. My initial thought is this in the Post settings may not get the new value until the program is completed, which is after Post settings have been run. Using a Result element may show us something, and it may not. Link to comment Share on other sites More sharing options...
