GOM Inspect 2019 compatible with Comet L3D 2 5m
One of our other departments is discontinuing the use of their Comet L3D2 and I have the chance to upgrade from my ATOS unit. I have experience with GOM Inspect but zero experience with Calypso. Is it possible to capture data with the Comet through GOM inspect 2019?
Hi Travis,
GOM Inspect cannot be used to measure with the Comet, but you could import the mesh into Inspect to keep evaluating with Inspect. Measuring is done in "Colin 3D" apparently with the Comet.
What ATOS sensor are you currently using?
Nanno
I'm using a Triple scan. I understand that this unit is no longer supported and was hoping to replace with the Comet.
Hi Travis,
a couple of "old" Triple Scans work up until Inspect 2025 (from 2026 release notes):
