[Ed...] Posted 17 hours ago Share Posted 17 hours ago (edited) Hello, Could someone explain me how to evaluate undercut and max edge finish? This is how I made it: I have arguing our engineers of this topic, because they say the tolerance should be from -20 to 90 microns. Edited 17 hours ago Link to comment Share on other sites More sharing options...
[Ch...] Posted 13 hours ago Share Posted 13 hours ago would be difficult, pretty sure gear pro does not have this, even if it did, you would need the proper ball to shaft ratio probe tip to not shank. Looks like you do have it measured - which is a start. Looks like you may be able to add a root relief and try that, or possibly add a K-band in this area as well. Worst case, try reading on chart, counting dots - not ideal, however. Link to comment Share on other sites More sharing options...
[Ro...] Posted 10 hours ago Share Posted 10 hours ago Can you provide more background what exactly is meant with Undercut. Undercut could be in general a root relief or Undercut evaluation characteristic which is not defined in standards. I know that e.g. Klinglenberg has such an charactersistic but you have to clarify what exatly has to be evaluated. Same for the other charateristic. Maybe you can share the drawing and the .act via PM? Link to comment Share on other sites More sharing options...
[Ma...] Posted 8 hours ago Share Posted 8 hours ago I'm not for sure but aren't those surface roughness callouts to be measured with a profilometer? Rv (maximum valley depth) is one of the options on our formtracer Re is not but a google search shows it is not a standard primary roughness parameter but may be in reference to Rc or Rp. I have not used any of these parameters, so I have nothing else Link to comment Share on other sites More sharing options...
