Running blocking gom.script calls without freezing a background polling loop, inside a locked ZEISS INSPECT addon
Hello,
My add-on needs to run a blocking GOM command while a Modbus polling loop keeps running for a two-station workflow.
Since GOM commands can only run on the main thread, I tried using multiprocessing.Process for the blocking scan. This works in the edit mode, but after the add-on is locked and packaged, the child process fails with ModuleNotFoundError when importing the add-on module.
Using a temporary .py file with subprocess is not an option because it would expose the source code.
I also tried threading, but it sometimes causes unexpected crashes in software, so I would prefer not to use it.
Is there an official way to use multiprocessing or a separate Python process in a locked add-on without exposing the source code?
If not, what is the recommended way to handle this kind of two-station parallel workflow?
  • 3 weeks later...
I've studied services and those are mainly for sharing functions across many add-ons.
But it's like for calculations - not for dialogs.
If anyone needs a function, which should return calculated result defined by parameters, then this can be used. But i don't think you can hide code or use compiled python code. At least i didn't try "pyc" file
