[va...] Posted yesterday at 02:29 AM Share Posted yesterday at 02:29 AM After the program is successfully finished the last probe freezes for long time away from part and does not move. If left untouched it takes its own time to finish calculating everything and the probe starts moving again back to clearance zone and then report is generated. It was only on certain operations but now same issue with almost every program causing delays. Is the problem with Calypso or is it CMM machine problem? How do I fix this? Thanks in Advance. Link to comment Share on other sites More sharing options...
