[Ri...] Posted 7 hours ago Share Posted 7 hours ago (edited) I have several variables I need written to a PiWeb report. I am bypassing Calypso's normal input screen "Input Parameter" for header data to control what gets entered. I am using vb.net in an interface where the Serial number, Mach center, operator and WOID will be collected for strict control of what is entered. Current para file variables to write to PiWeb. OpSerNo="SC-999" OpMachCtr=K999 OpOper=M999 OpWOID=45009999 Using OpSerNo for this exercise (Solve one should solve all) with PCM. u_SerNumb=OpSerNo (works and resolves to "SC-999") But this resolves to nothing OpSerNumb=getRecordHead("u_SerNumb") Once that is solved, how do I pass the OpSerNumb to Piweb's "Incremental Counter"? (I use the Incremental Counter as a Counter and or Serial Number) (Interface shown in the image) Edited 7 hours ago Link to comment Share on other sites More sharing options...
[Ri...] Posted 3 hours ago Author Share Posted 3 hours ago I figured it out, I forgot (again) about the userfields.ini file. Oops. Link to comment Share on other sites More sharing options...
