[ca...] Posted August 18 Share Posted August 18 Hello all, We are running ZEISS INSPECT in an automated environment with multiple INSPECT instances, and we occasionally encounter the “Graphics Card” dialog shown in the attached screenshot when an instance starts. The GPU is detected correctly, Hardware rendering (default) is selected, and the graphics card/driver is reported as compatible with no known problems. However, this dialog still appears intermittently. This is an issue for us because our INSPECT instances are started and controlled automatically. When this dialog appears, it requires user interaction and therefore interrupts/block the automation workflow. Could you please clarify: 1. What can trigger this Graphics Card dialog to appear intermittently? 2. Is there a way to disable/suppress this dialog permanently without using software rendering? 3. Can we force ZEISS INSPECT to always start with Hardware Rendering via a configuration file, command-line parameter, environment variable, or Python/script API? Thanks, Canset Link to comment Share on other sites More sharing options...
[Ma...] Posted August 18 Share Posted August 18 I would guess to change default GPU for process in Windows to utilize only RTX and not iGPU. I am sure on knowledge base or in this forum will be shown how to setup for Calypso - same should be for Inspect. Link to comment Share on other sites More sharing options...
[ca...] Posted 3 hours ago Author Share Posted 3 hours ago Thanks for the suggestion. However, I see the same issue on another workstation that has only an NVIDIA RTX GPU, with no iGPU available. The popup still appears intermittently there as well. So it seems that, at least in my case, the problem may not be related to Windows selecting the wrong GPU. I would need some more detailed information from ZEISS about how INSPECT handles GPU initialization and hardware rendering, especially in multi-instance scenarios, and whether there is a supported way to force hardware rendering consistently or assign specific GPU resources to each instance. Link to comment Share on other sites More sharing options...
[Na...] Posted 1 hour ago Share Posted 1 hour ago Hi Canset, could you reach out to support with reference to this thread? Nanno Link to comment Share on other sites More sharing options...
[Ra...] Posted 7 minutes ago Share Posted 7 minutes ago Please sign in to view this quote. Since this appears to be an automation use case, I'd escalate with: ZEISS INSPECT version Exact startup command line Number of concurrent INSPECT instances Whether instances run under the same Windows user Whether the system is local, RDP, VM, Citrix, or remote session GOMSIC from a launch where the dialog appears GOMSIC from a launch where it does not appear Screenshot of the dialog (the one you attached) I would specifically ask: Please sign in to view this quote. Link to comment Share on other sites More sharing options...
