Two meshes alignment
Hello Marcin,
multipart projects are a Pro feature, so you are stuck with one nominal and one actual mesh element for alignments. If you want to compare a measured part before and after some machining for example, you can define one mesh as the nominal (ZEISS Quality Tech Guide (gom.com)) to compare them.
Nanno
  • 2 weeks later...
