[yo...] Posted Thursday at 06:04 PM Share Posted Thursday at 06:04 PM Hello everyone, I am relatively new to Calypso but already have some experience with other CMM software. I would like to measure a simple dimension AB (see the attached photo). This dimension involves an angle, but that shouldn't be an issue in Calypso. To measure this distance, I follow these steps: 1- Create points A and B. 2- Configure clearance and retraction settings based on the geometry. 3- Create another point near A and construct a line. 4- Measure using the "perpendicular" function (between B and the previously created line) and select the "depth" option. Do you agree with this approach so far? If so, my question concerns how points A and B are captured. I have the choice between "Touch Point" and "Space Point." I should mention that I do not have a CAD model. With "Space Point," the AB dimension can vary significantly just by slightly altering the direction of the i, j, and k vectors. Which point capture method do you recommend for my application? I hope this is clear. Thanks for your help. Link to comment Share on other sites More sharing options...
[Ma...] Posted Thursday at 06:20 PM Share Posted Thursday at 06:20 PM I usually use Plane point - forcing vectors to nominal. Link to comment Share on other sites More sharing options...
[yo...] Posted 8 hours ago Author Share Posted 8 hours ago Hi Martin, Thank you for your advice. I set my point with a plane point but i don't see any improvement in my results they are not stables. I noted that there's 3 different option to determine the normal: - Probing direction - Plane measurement always - Plane measurement in manual I didn't find in the manual any explanation on this matter, but they affect a lot my results and the stability. When i choose ''plane measurement always'' because my faces are little, the probe miss the surface and then the normal vector is affected and of course my results. Also, when i create my line ( i attached a figure), the line is not connected to the 2 points. Is it a graphical issue or a problem in my construction? Thank you for your help. IMG_1670.HEIC IMG_1668.HEIC Link to comment Share on other sites More sharing options...
[Ma...] Posted 6 hours ago Share Posted 6 hours ago Do you have at least drawing? I don't understand how you got this 2d line. Did you use recall or recall measured points? I think that using such sketch is not much helpfull, because everyone from us are looking onto problems differently. Just to summarize: tolerances, problems with definition for CNC scan, varying results in what range, drawing vs used characteristic. There can be many right choices with very different approaches. Also sometimes scale of real part vs magnified drawing can be misleading. Link to comment Share on other sites More sharing options...
