Dewarp - Clamping force
Hi team ,
I want to create label with clamping force with unit(N) , but the unit of force is not visible in the result.
If i rewrite in the template to newtons then i have everything in newtons🫣
Is that even possible?
Many thanks for any advice.
image.png.63df695682678ace4e06c9d840461b65.pngimage.png.819ad14aa2e4416bae95d2437c43f8fe.pngimage.png.6a7a2a6d7b87743f1740330553124cec.png
OK, so you can use existing template, just edit it, double click on text in column where you wont to show it.
At the end of a text there is "show_unit = false" and change that to "true"
For deviation column it's a bit tricky to find correct text
  • Awesome! 1
Hi Martine ,
many thanks ,all variants work, good job 👍.
I try to make a new one from actual template( see below).
Have a good one
Hi,
just to keep in mind: The clamping forces with Dewarp are usually higher than in reality because the deformation model is stiffer, because of the stiffer voxel based deformation model.
Nanno
Hi  Nanno,
So, it can be said that the clamping forces depend on the deformation model, isn´t it ?
Thanks to the info
