[At...] Posted September 10 Share Posted September 10 Hi! I need to measure a small 0.92mm plastic hole using 143 points. What filter settings should I apply? Thank you! Link to comment https://qualityforum.zeiss.com/topic/27408-filtering/ Share on other sites More sharing options...
[Er...] Posted October 7 Share Posted October 7 I usually use 15upr, Gauss, Low-pass. I would use more points to help the calculation. Link to comment https://qualityforum.zeiss.com/topic/27408-filtering/#findComment-156655 Share on other sites More sharing options...
