PDF File PiWeb Reporting - File Overwriting Issues
Hi all,
I wanted to know if anyone has a solution for a problem I am seeing.
Example: We run parts and have the PDF Files setup to autosave at the completion of a run. Say I run "Part A_Run 1" and it fails. I modify it and need to run it again, it should be "Part A_Run 2" and if so, everything works fine. What is happening is that operators aren't remembering to correctly rename the Run number so the might run another "Part A_Run 1" and it overwrites the file in the directory we have it going to without asking something like "Are you sure you want to save over this?" or "There is already something named this...blah blah"
Is there a way to prevent file over-writes so that we don't have this happen? Lost a few files today because of this issue and I don't have an easy fix for it without telling the operators you really need to pay attention to the Run number to ensure you aren't repeating something already in the folder.
Thanks
I would set up variable file naming and probably use getRecHdForFil("time") to add a timestamp to the file name. That way it should be unique even if the same run number is used.
Changed PCM command to file-safe one
Love that idea! It won't change the inputs the operator has to make but will add a timestamp to the file whenever it is saved to prevent the overwrite issue I am seeing. Thank you for this!
