[Ri...] Posted Thursday at 04:38 PM Share Posted Thursday at 04:38 PM Please, please, please stop this behaviour. Link to comment Share on other sites More sharing options...
[Ra...] Posted Thursday at 04:43 PM Share Posted Thursday at 04:43 PM Hello, Please share this request to the My Voice portal. https://portal.zeiss.com/my-voice/software/metrology Link to comment Share on other sites More sharing options...
[Ri...] Posted Thursday at 04:59 PM Author Share Posted Thursday at 04:59 PM Please sign in to view this quote. I have requested multiple things for Inspect, but I do not see any feedback from Zeiss. These were posted all the way back in 2024. https://portal.zeiss.com/my-voice/software/metrology/product/eaafdea8-9296-485d-82c1-cc6d1ca0eca2/request/c3051e15-87d9-436b-a489-1b142d7d6559 https://portal.zeiss.com/my-voice/software/metrology/product/eaafdea8-9296-485d-82c1-cc6d1ca0eca2/request/f0335067-2822-4b52-8912-fd2c2f43d696 Link to comment Share on other sites More sharing options...
[Ri...] Posted Thursday at 05:17 PM Author Share Posted Thursday at 05:17 PM And to add to the confusion: what exactly is out????????? Link to comment Share on other sites More sharing options...
[Ch...] Posted 14 hours ago Share Posted 14 hours ago Regarding your last post. The linear size check do not measured the virtual condition, due to the fact * for datum B your linear size check do ignore the perpendicular constraint to datum A * for datum C your linear size check do ignore the perpendicular constraint to datum A and the distance constraint to datum B We are quite sure that we compute the virtual condition quite exact but if your sure that there is really a computation mistake please contact your local support contact. Regarding your first post: Due to the fact that MMR computation is the simulation of a gauge, you have to check if it possible to put a virtual gauge (based on your nominal sizes) into your drills (or bolts). If this failed the error message appears. We don't see how it should possible to provide a standard conform datum system without this check (and the error message if this check is failed). Of course, we could and should think about more user feedback what exactly is going wrong. This is already on our list for further improvements. Link to comment Share on other sites More sharing options...
[TI...] Posted 1 hour ago Share Posted 1 hour ago We cannot use MMR on datums due to this virtual condition being violated error. Please sign in to view this username. when I have time I will carefully go thru this error and send zeiss an email, b/c I understand what you are saying, but I don't think something is correct. Now, there is another real issue that needs to be fixed regarding MMR on datums in Zeiss Inspect and that is that all subsequent datums must have MMR used. Even if the last datum is a plane like you would place the part on a surface plate. You cannot have MMR on a surface plate. Link to comment Share on other sites More sharing options...
[TI...] Posted 1 hour ago Share Posted 1 hour ago Please sign in to view this username. Let's spitball this for a second. Let's take the image above as an example. Datum A MMR is 35.1mm. So as long as that Datum Cylinder is machined below 35.1 at all cross sections(local size) there should be no violation bc you would be able to fit that datum Cylinder into a gauge machined at 35.1mm and rattle it around to help the cross thru hole positional check. Now let's assume that Datum A is LMR so its virtual size is 34.9mm. You cannot do gauging for LMR, but it is a legit usage of datum material requirments so you cannot build any type of gauge for this. I'm not sure how the software is going to behave with LMR, but I will try it out later when I have time. It may just not allow you to use it if the whole concept inside the software is hard guaging theory. Link to comment Share on other sites More sharing options...
