Annoying Elements in the CAD Window
Hi guys, does anyone know of a way to permanently remove these elements that Calypso creates and that are visible in the CAD window?
Even after deleting them using Modify CAD Entities and saving the program, they reappear when I reopen it and remain visible in the CAD window.
Is there a way to remove them permanently?
Im using Calypso 2025 SP4 V 8.0.16, this is a issue i have in all V8 releases i dont know if in older versions this is a issue.image.thumb.png.e3422d90f60a4c1ceeb92241bf8a67f4.png
I'm not at my workstation but it's something line CAD/Settings/Geometry/ and uncheck everything except the alignments.  This is my preference but you can work with these checkboxes.  I think the one you're looking for is like "show all 3d features on CAD"
That plane won't disappear until you click away from it and back on it.
Sometimes they are persistent.  When this happens, use the button underneath the CAD window "Show all geometric features" and then toggle back to "Show CAD"
I hate these things.
Thank you i finnaly found out the option that hide this crap..
These elements appear when the corresponding CAD surface is not (or no longer) associated with the element. This happens either when you replace the CAD model with a new version or when you define a feature manually without clicking on the CAD at all. You can reassociate them to the CAD by using the CAD model comparison, but the procedure is a bit awkward and doesn't always work 100%.
  • Like! 4
 THANK YOU!  It felt like my program would get "corrupted". This works! Thank you!
  • Thank you! 1
UPDATE: I tried the “Show 3D geometry features on CAD model” option in several programs, but in most of them it didn’t work. These annoying elements still appear.
yes i try all options, the only thing that works is link again this planes to the cd model, that works for now
