[Aa...] Posted 2 hours ago Share Posted 2 hours ago Hello everyone, Our supplier needs to measure a cylinder with four sections milled away: The remaining arcs are about 30° wide and spaced 90° apart, so there should always be opposing points. We want each arc scanned with high point density and the points combined into one circle. From that circle we want to evaluate: - the two-point size (LP)(SX)/(LP)(SN) - LSQ-roundness (least squares not minimum zone) The supplier says neither can be evaluated because the circle is incomplete. Can Calypso do this or not? Could someone point me to a setup or example I can pass on to the supplier? Thanks for any advice! Link to comment Share on other sites More sharing options...
