[Ch...] Posted September 21 Share Posted September 21 (edited) Has anyone programmed a dynamic profile from ASME 14.5 2018? How do you program the bottom refinement portion which contains the dynamic profile? For example, I have a hex nut where I want the hex OD to be very concentric to the threaded ID. The size isn't that important, but orientation is. Edited September 21 Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/ Share on other sites More sharing options...
[Ch...] Posted September 21 Author Share Posted September 21 This is where I'm having a brain fart. How can I tell Calypso to allow my tolerance to zone to expand or contract based on the size of the feature? "This tolerance zone may expand or contract while controlling the form, orientation, and location of the feature within the 0.15 tolerance zone, allowing the size of the feature to uniformly progress. The actual feature shall simultaneously be within both tolerance zones." Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-155895 Share on other sites More sharing options...
[Ma...] Posted September 21 Share Posted September 21 Theoretically you can calculate an diameter and based on it's dimension you can set profile tolerance offset. Unless ZEISS will make this option inside Calypso. Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-155899 Share on other sites More sharing options...
[Ch...] Posted September 21 Author Share Posted September 21 Please sign in to view this quote. This isn't a bad idea. I will have to play with this. Please sign in to view this quote. Zeiss should make this an option in Calypso. Dynamic profile was released in ASME 14.5 2018. So its fairly new. But I see a lot more designers getting interested in using dynamic profiles and I suspect we'll all be seeing this more often. Get ready folks. Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-155905 Share on other sites More sharing options...
[Ed...] Posted September 21 Share Posted September 21 I haven't been able to test this, but I was thinking that dynamic profile should be the difference between MAX and MIN from Profile bilateral two results. Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-155909 Share on other sites More sharing options...
[Ja...] Posted September 21 Share Posted September 21 Please sign in to view this quote. Somewhat, in the example shown its a refinement, the total deviation is allowed to be .015, but allowed to float within the .025 total band. In some other case dynamic profile will affect the shape of the tolerance zone, might be held narrower at the ends and allowed to be larger in the middle portion. I haven't done much with Dynamic Profile in Calypso, but will look into it. Possible that the function isn't currently available in Calypso 2025, but I'm not sure as i haven't checked. Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-155911 Share on other sites More sharing options...
[Ch...] Posted September 22 Author Share Posted September 22 I'm just bumping this one up, does anyone have any ideas? Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-155981 Share on other sites More sharing options...
[Er...] Posted September 23 Share Posted September 23 Least amount of effort is to use curves and the offset function under evaluation. 3 Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-155985 Share on other sites More sharing options...
[Ri...] Posted September 23 Share Posted September 23 In the context of dynamic profile, could we calculate the difference of the size of the feature and add or subtract from the tolerance with PCM? 1 Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-155997 Share on other sites More sharing options...
[Ch...] Posted September 23 Author Share Posted September 23 Please sign in to view this quote. I plan on testing this, just need to find time to do it. 1 Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-156001 Share on other sites More sharing options...
[Ri...] Posted September 23 Share Posted September 23 Please sign in to view this quote. I am still wrapping my head around dynamic profile and how to report it, I have not had time to test the theory. Hearing if this works or not will be interesting to say the least. Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-156005 Share on other sites More sharing options...
[Ma...] Posted September 23 Share Posted September 23 Theoretically this profile has to be within tolerance with it's max deviations from both sides. Like form Deviations can be from -0.025 to +0.125 to fulfill both conditions - their distance is within 0.15 ( +- 0.075 from center curve ) and within 0.25 ( +- 0.125 from nominal curve ) Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-156025 Share on other sites More sharing options...
[Jo...] Posted September 25 Share Posted September 25 I have wondered if "Curve Jump" would not work to evaluate a dynamic profile (In 2D anyways...). It operates on a similar theory Link to comment https://qualityforum.zeiss.com/topic/27459-dynamic-profile-of-a-surface-of-revolution/#findComment-156145 Share on other sites More sharing options...
