Location of a pattern
I have a rectangular pattern of six holes on the top plane. The top plane is datum A. The engineer want the best fit location of the pattern to datum A. Would I have to create a new feature derived from all of those holes? If so could I just do a circle and recall?
Hi
What version of Calypso are you working with? Both the new GD&T engine and classic engine can support pattern location for position, but the route to accomplish this task differs.
You can also use a best-fit alignment with respect to Datum A.
