[Ja...] Posted March 15, 2023 Share Posted March 15, 2023 Hello all, I am new to GOM inspect and am in need of someone that has experience with creating offset planes. Here is what I have to work with. Datum A consists of 4 different planes, two of which are offset by 1.2 mm. (please see attached) Is this possible with GOM inspect? Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
[ra...] Posted March 15, 2023 Share Posted March 15, 2023 bonjour ,dans ce cas de figure tu peux partir de ton plan de ref A créer un plan // a celui-ci de 1.2mm par raport A et tu obtiens ton plan de ref ↔1.2 /ref A. Link to comment Share on other sites More sharing options...
[Na...] Posted March 16, 2023 Share Posted March 16, 2023 Hello Jarred, please see the direct help (section "common datums") for this: ZEISS Quality Tech Guide (gom.com) It is also covered in the starter training GD&T: (eLearning) 947 Starter Training GOM Software (GD&T) (Software 2022) @Rahaoui please use German or Englisch 🙂 To use the common plane as a datum system like in the drawing, a parallel plane is not correct. Regards, Nanno Link to comment Share on other sites More sharing options...
