[Da...] Posted 23 hours ago Share Posted 23 hours ago We're going to be investing in some Curve licenses and got offered a Curve/FF bundle option. What's the difference between Curve and FreeForm? For some context, we have one Curve license now that we've been utilizing more in recent months. We're also considering a CMM outfitted with a LineScan for surface profile inspections. Link to comment https://qualityforum.zeiss.com/topic/27818-curve-vs-ff/ Share on other sites More sharing options...
[Ma...] Posted 22 hours ago Share Posted 22 hours ago I may not know exactly what is possible without FF, but i know you can use 2D and 3D curves to evaluate line profile. With FF you can create surface feature and do scan paths on selected faces of a model. Also you can recall all measured points into this feature and select which faces should be evaluated. In other words - curves has nominals inside them - FF is using model for calculations. We were told ( forged parts ) we absolutelly need curves and ff. Link to comment https://qualityforum.zeiss.com/topic/27818-curve-vs-ff/#findComment-157888 Share on other sites More sharing options...
[Ke...] Posted 3 hours ago Share Posted 3 hours ago If you do a lot of surface profiles, I would definitely get the FreeForm option. In my experience, pretty much everything is doable without it, but it saves a lot of time for evaluations that cover multiple features. Link to comment https://qualityforum.zeiss.com/topic/27818-curve-vs-ff/#findComment-157924 Share on other sites More sharing options...
[Ri...] Posted 2 hours ago Share Posted 2 hours ago I am a yuge FreeForm fan. I put that shlt on everything. 😁 Link to comment https://qualityforum.zeiss.com/topic/27818-curve-vs-ff/#findComment-157926 Share on other sites More sharing options...
