[Jo...] Posted Saturday at 03:20 PM Share Posted Saturday at 03:20 PM I need to organize the elements in the table so that my reports dimensions appear in the correct sequence. Currently, they are listed out of order (1,4,2,5,3, ect.). How can I organize the elements so the dimensions are reported in the proper order? Link to comment https://qualityforum.zeiss.com/topic/27846-organizing-elements-in-table/ Share on other sites More sharing options...
[Ma...] Posted yesterday at 08:37 AM Share Posted yesterday at 08:37 AM What i did i modified table template to show dimension number from drawing. Since we use a lot QDAS, then for every dimension ( sometimes it's inside element, sometimes in exact dimension ) i enter keywords "qdas_k2001" and value. I placed this value to new first column and let sort by this. Otherwise it's sorting by name, but also by that icon, so it's grouped by type of element. Link to comment https://qualityforum.zeiss.com/topic/27846-organizing-elements-in-table/#findComment-158058 Share on other sites More sharing options...
[Jo...] Posted 7 hours ago Share Posted 7 hours ago You can sort the table by clicking on the column header of each column. You then get a little symbol in the the header field symbolising the sorting dicrection. Link to comment https://qualityforum.zeiss.com/topic/27846-organizing-elements-in-table/#findComment-158068 Share on other sites More sharing options...
[No...] Posted 7 hours ago Share Posted 7 hours ago (edited) If you need a specific order all you can do is to either add a sort column like Martin decribed or to name your elements with a leading sort number. What we do is to put the drawing's bubble number in front of our measurement names. Edited 7 hours ago Link to comment https://qualityforum.zeiss.com/topic/27846-organizing-elements-in-table/#findComment-158072 Share on other sites More sharing options...
