Probing System Qualification
A little bit of information before my question, I am using a spectrum CMM with a passive Vast XXT with rotating head, my reference sphere is at 180 for angle 0 for tilt and it positioned as close to center as I can get. I am also running calypso 2019.
I am attempting to set up a program to automatically qualify my probes using the probing system qualifications characteristic, I have to manually put on and take off my master probe to get reference sphere location due to rack space limitations. Then I run the program, it will do my first probe a 3mmx50mm no problem but then it will attempt to do all my other probes, and it will hit a limit switch usually on my X axis sometimes Z. I'm stuck on what I need to change or if there is another way of doing this.
https://qualityforum.zeiss.com/topic/27854-probing-system-qualification/
  • 2 weeks later...
