[M...] Posted 10 hours ago Share Posted 10 hours ago I cant create distance between two planes, it isnt as opposite. Is possible inspect GG distance? Link to comment https://qualityforum.zeiss.com/topic/27862-distance-between-two-planes/ Share on other sites More sharing options...
[Jo...] Posted 10 hours ago Share Posted 10 hours ago Hello, this thread could help. Link to comment https://qualityforum.zeiss.com/topic/27862-distance-between-two-planes/#findComment-158186 Share on other sites More sharing options...
[M...] Posted 8 hours ago Author Share Posted 8 hours ago I'd like to check distance between middle surface point and plane. But my point is in air. Which measure principle for surface point can I use? Link to comment https://qualityforum.zeiss.com/topic/27862-distance-between-two-planes/#findComment-158206 Share on other sites More sharing options...
[Ma...] Posted 7 hours ago Share Posted 7 hours ago You can select faces and use fitting point. Then select refferenced principle. Now you can use projected distance. Link to comment https://qualityforum.zeiss.com/topic/27862-distance-between-two-planes/#findComment-158210 Share on other sites More sharing options...
