New to 7.4 Calypso
We recently got a new Duramax and was trying to run 6.8. We were told we had to go to at least 7.4.  No big deal, except for....I can't figure out how to make form plots like I could in 6.8.
We use Curve and scan a "cam" shaped ID and the operators and engineers use these form plots as good visuals of their process. I know that in 7.4 "Presentation" pdf for reports is gone although it still works with the programs that were created in lower versions of Calypso.
So yesterday I was creating a program that I was able to do a "save as" to and adjust some things as needed.  I couldn't get the image(form plot) of the "Curve Form or even Graphic Element to work. I eventually got to  point to where an image/plot would show up, but when I ran the program all that popped up was the data("presentation pdf")
I did a file save as and switched to using PiWeb reporting which I am not really familiar with, I have trouble making reports save to network location desired. Still got no images or plots.
#1 What needs done for form plots to populate or show at the end of a run in 7.4?
#2 What took the place of Graphics Element in 7.4 like in older versions of Calypso, looking to have data and images saved into one pdf.
#3 What is the trick to getting pdf reports in/using PiWeb type to save to a network location even though in Resources>Name for output files>...for this measurement plan, I have given the correct file path for the data.
Lincoln
https://qualityforum.zeiss.com/topic/27864-new-to-74-calypso/
