[Da...] Posted 1 hour ago Share Posted 1 hour ago I browsed a few posts but could not find a clear method to find the tangent angle for the characteristics shown in the screenshot. It's for a family of parts so I'd like to have a repeatable method. What's the best way to find report this? Link to comment https://qualityforum.zeiss.com/topic/27866-find-tangent-angle-of-a-slot-radius/ Share on other sites More sharing options...
[Ri...] Posted 37 minutes ago Share Posted 37 minutes ago (edited) I recently did what you need. See attached image. Create a point at the center of the part (Theoretical, intersection, projection, etc). Scan the radius. Drop in a "Tangents" ----Construction, Tangents Select the Point and the Circle of your radius. P.s. I have an alignment that allows me to create the radius in the correct geometry location. (Trihedron showing =Z axis to center of Circle21). It seems like we are doing the same type of slot, my dims are quite similar to yours. Edited 30 minutes ago Link to comment https://qualityforum.zeiss.com/topic/27866-find-tangent-angle-of-a-slot-radius/#findComment-158200 Share on other sites More sharing options...
[Ri...] Posted 31 minutes ago Share Posted 31 minutes ago (edited) Deleted Edited 30 minutes ago Link to comment https://qualityforum.zeiss.com/topic/27866-find-tangent-angle-of-a-slot-radius/#findComment-158202 Share on other sites More sharing options...
[Ma...] Posted 2 minutes ago Share Posted 2 minutes ago Can you make a theoretical circle from center and radius to center of groove's circle to intersection? Link to comment https://qualityforum.zeiss.com/topic/27866-find-tangent-angle-of-a-slot-radius/#findComment-158204 Share on other sites More sharing options...
