[Jo...] Posted Friday at 07:59 PM Share Posted Friday at 07:59 PM Have a new engineer here wanting to do a gage R&R on the cmm. Wants to do it on a raw casting. My opinion bad idea seeing as i check castings everyday. What is others opinion? Have the zeiss training block could do it on. Link to comment https://qualityforum.zeiss.com/topic/27884-gage-rr/ Share on other sites More sharing options...
[DW...] Posted Friday at 08:28 PM Share Posted Friday at 08:28 PM Please sign in to view this username. If he is trying to prove the CMM is repeatable, no to the casting. There's too much variability with raw parts. Use a more refined, known artifact like your training block. If he is looking at production measurement system capability, then let him use the castings. I'd do both, so you can show the variability that exists between them. Link to comment https://qualityforum.zeiss.com/topic/27884-gage-rr/#findComment-158302 Share on other sites More sharing options...
[Ja...] Posted 2 hours ago Share Posted 2 hours ago I do a five run R&R on every single characteristic in every program I write, including cast surfaces. This includes removing the part from the fixturing and placing it back in the fixturing so I know that process repeats too. If something doesn't fall within the 10% measurement error rule, I change the scanning, filtering, or whatever else it takes to get it to repeat (and be accurate). If it doesn't repeat, how do I know which measurement is the right one (if any)? There are so many programmers out there that don't want to do R&Rs and I don't know why. It only makes you a better programmer, and people trust the numbers you give them. The big drawback of course is the amount of time it takes to prove out a program. The last program I had one of my operators prove was a big one and took about a day and a half to do the R&R. They don't like the time factor, but they, the machinists, and the engineers are much more confident in the numbers they're seeing and are willing to wait. I do make exceptions though for really big programs (ones that take 2 or 3 hours for each run) or the really big parts that take a crane to lift. I'll usually only have them do a 3 run R&R. Link to comment https://qualityforum.zeiss.com/topic/27884-gage-rr/#findComment-158352 Share on other sites More sharing options...
