[M...] Posted 15 hours ago Share Posted 15 hours ago I created report with customized table. Then exported as custom template. Now my custom template create table with default column (overview template). How to create template with custom table column? Link to comment https://qualityforum.zeiss.com/topic/27898-custom-table-to-template/ Share on other sites More sharing options...
[Jo...] Posted 15 hours ago Share Posted 15 hours ago Have you choosen the templat you created in the drop down menue? you can have a look here: https://techguide.zeiss.com/en/zeiss-inspect-2027/article/general_view_table.html 1 Link to comment https://qualityforum.zeiss.com/topic/27898-custom-table-to-template/#findComment-158434 Share on other sites More sharing options...
[M...] Posted 1 hour ago Author Share Posted 1 hour ago Ok, I found it. Is there setting for fixed column width in table? Now column width is set as fit to content. Link to comment https://qualityforum.zeiss.com/topic/27898-custom-table-to-template/#findComment-158444 Share on other sites More sharing options...
