Rotating CAD
Hello all...
I got a prg from a supplier so we can be on same sheet of music so to speak. I need to rotate the part on mu machine so as to use my existing probes. Ill have to rotate in X and Z. When I rotate the part, the ABC datums stay the same on the screen but the part rotates as I need it too. It leaves the datums out in the air.
Thanks
https://qualityforum.zeiss.com/topic/27902-rotating-cad/
If you really want/need to rotate the CAD, your only choice is to modify every single feature to match the new orientation. What you can do is to make a theoretical secondary alignment that matches the new orientation, then change every feature's coordinate system to the new one with the "keep position" checkbox checked. Then change back again with the checkbox unchecked. This should transform all features correctly.
But Calypso can also handle a flipped base alignment as long as every feature is still reachable. You would just need to adapt the styli used and then manhually measure the base alignment exactly as directed by Calypso. All it takes is a bit of brain acrobatics.
https://qualityforum.zeiss.com/topic/27902-rotating-cad/#findComment-158448
