[Na...] Posted Thursday at 03:08 PM Share Posted Thursday at 03:08 PM Hello everyone, My company is planning to purchase their first Zeiss CMM (Contura 9,12,6). Aside from the necessary things, what would say you couldn't live without? I plan to have a decent selection of probes and extensions as we are more of a job shop so things can vary. I plan to have like 6-9 preset probes for most things but having options is always good. We are considering using the option to switch between rds and other sensors. I know some things are subjective and will vary by use cases. We don't do much with castings mostly machined from bar stock or pre-cut blanks. We do make some die parts so some of the things will be verifying them. Most is steel but we do also do some aluminum and other materials like g10. All suggestions are appreciated. Thanks in advance, Nathaniel Link to comment https://qualityforum.zeiss.com/topic/27908-first-zeiss-cmm-purchase-wishlist/ Share on other sites More sharing options...
[Ma...] Posted Thursday at 03:25 PM Share Posted Thursday at 03:25 PM It's all about budget. I would push for curve and free form. Having RDS is really a plus - you can reach almost anywhere without special probe config. I can not compare an active head to a passive head, but i believe with a slowdown compared to active head you can do the same. I think you won't need anything else than RDS - machined faces are shiny, so i would not try linescan or optics ( if they are available ). Perhaps rotary table or if you are dealing with gears, then GEAR pro option Link to comment https://qualityforum.zeiss.com/topic/27908-first-zeiss-cmm-purchase-wishlist/#findComment-158464 Share on other sites More sharing options...
[Na...] Posted Thursday at 05:00 PM Author Share Posted Thursday at 05:00 PM I was considering the rotary for larger parts due to size constraints when that comes up. Link to comment https://qualityforum.zeiss.com/topic/27908-first-zeiss-cmm-purchase-wishlist/#findComment-158466 Share on other sites More sharing options...
[Ma...] Posted 4 hours ago Share Posted 4 hours ago I wish I had a rotary table where I work. It would have mad a great many things much easier. RDS is a great option but with 2.5 degree articulation I sometimes need to get creative. dot scan can be useful at times depending on a lot of factors. Link to comment https://qualityforum.zeiss.com/topic/27908-first-zeiss-cmm-purchase-wishlist/#findComment-158536 Share on other sites More sharing options...
