[Sh...] Posted yesterday at 11:19 AM Share Posted yesterday at 11:19 AM I have installed the latest Calypso 2025 service pack and Calypso 2027 with the latest patch. Planner/Simulation is not working correctly, does not simulate probe measurement accurately at all and is not touching in correct spot on a CAD model for both versions. Calypso 2027 seems to have a glitch with ZAS specifically where it shows it offset at first but then changing probes or turning simulation on and off fixes it. Both have the same issue with the probes not touching the model correctly regardless. Let me know if any of you see the same problem. 1 Link to comment https://qualityforum.zeiss.com/topic/27914-calypso-2025-latest-service-pack-calypso-2027-planner/ Share on other sites More sharing options...
[Ja...] Posted 20 hours ago Share Posted 20 hours ago I'm running the latest version of 2025. I had that problem with the last program but hadn't had it at all prior to that. It must stem from the last patch of 2025. It sounds like 2027 is just as buggy as 2025 was when it first came out. I'm going to wait for the 1st service pack to come out before installing 2027. 1 Link to comment https://qualityforum.zeiss.com/topic/27914-calypso-2025-latest-service-pack-calypso-2027-planner/#findComment-158528 Share on other sites More sharing options...
[Ka...] Posted 3 hours ago Share Posted 3 hours ago Hi Shawn, Do you mean that the button shown doesn’t line up with the crosshairs? This is already happening in CALYPSO 7.4 According to ZEISS support, there is no way to fix this. The ‘solution’ is to delete the entire configuration of the virtual Zeiss machine and recreate it! Planner is simply an expensive piece of rubbish software that perhaps only works 80 per cent of the time. NOTHING remains of the glorious promises that CALYPSO 8.0 would bring a completely new Planner. At best, it’s the porting of a dreadful piece of software to 64-bit with a bit of face lift.... So bad! Link to comment https://qualityforum.zeiss.com/topic/27914-calypso-2025-latest-service-pack-calypso-2027-planner/#findComment-158546 Share on other sites More sharing options...
