[RP...] Posted 22 hours ago Share Posted 22 hours ago I'm scanning a very small cone and just noticed that my scans aren't lining up. I just qualified the probes this morning. What would be causing the points to look this way? Cad eval mag at 60x. Machine Used: o-inspect322 XXT 1mm probe in -Z. I'm recalling points from 2 cone features scanned on the same cone. One cone feature is scanning clockwise, the other scans counter-clockwise. 6 circle scans in each. Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/ Share on other sites More sharing options...
[Ri...] Posted 50 minutes ago Share Posted 50 minutes ago (edited) Give us an image looking into the center, right now it looks like two sperate centerlines. Edited 50 minutes ago Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158548 Share on other sites More sharing options...
[Ma...] Posted 27 minutes ago Share Posted 27 minutes ago What measuring force do you have? I was thinking that recalling measured points will recall real data and it will be recalculated on new element. This looks like it's giving back modified vectors from original element. What you can do is a tryout where you will have 2 separate cones as now and then try one cone with two strategies. Also only touch points can show different results. And in how big deviation we are talking about? 0,005mm? Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158550 Share on other sites More sharing options...
