[RP...] Posted Monday at 02:22 PM Share Posted Monday at 02:22 PM I'm scanning a very small cone and just noticed that my scans aren't lining up. I just qualified the probes this morning. What would be causing the points to look this way? Cad eval mag at 60x. Machine Used: o-inspect322 XXT 1mm probe in -Z. I'm recalling points from 2 cone features scanned on the same cone. One cone feature is scanning clockwise, the other scans counter-clockwise. 6 circle scans in each. Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/ Share on other sites More sharing options...
[Ri...] Posted Tuesday at 11:35 AM Share Posted Tuesday at 11:35 AM (edited) Give us an image looking into the center, right now it looks like two sperate centerlines. Edited Tuesday at 11:36 AM Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158548 Share on other sites More sharing options...
[Ma...] Posted Tuesday at 11:59 AM Share Posted Tuesday at 11:59 AM What measuring force do you have? I was thinking that recalling measured points will recall real data and it will be recalculated on new element. This looks like it's giving back modified vectors from original element. What you can do is a tryout where you will have 2 separate cones as now and then try one cone with two strategies. Also only touch points can show different results. And in how big deviation we are talking about? 0,005mm? Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158550 Share on other sites More sharing options...
[RP...] Posted Tuesday at 12:38 PM Author Share Posted Tuesday at 12:38 PM Please sign in to view this quote. I have the dynamic set to 25. and the vectors are constrained. the deviation is around 0,012mm. Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158552 Share on other sites More sharing options...
[RP...] Posted Tuesday at 12:40 PM Author Share Posted Tuesday at 12:40 PM It's the same feature, I've switched to just 4 circle scans. 2 clockwise and 2 counter. just to save time this morning. Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158554 Share on other sites More sharing options...
[Da...] Posted Tuesday at 07:28 PM Share Posted Tuesday at 07:28 PM How secure is your fixturing? Is it possible there is a small amount of deflection when scanning? Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158568 Share on other sites More sharing options...
[Ri...] Posted Tuesday at 08:47 PM Share Posted Tuesday at 08:47 PM Ok, so now it looks central. For gits and shiggles, make all your scans the same direction. Then let's see a graphic. Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158580 Share on other sites More sharing options...
[RP...] Posted Wednesday at 04:08 PM Author Share Posted Wednesday at 04:08 PM top image is half-cone angle characteristic, bottom image is a profile to empty datums. Mag at 100x. Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158620 Share on other sites More sharing options...
[RP...] Posted Wednesday at 04:12 PM Author Share Posted Wednesday at 04:12 PM the above post images were done with a 3.0mm probe, this post contains an image of an angular characteristic scanned with a 1.0mm probe. The distance between each circle scan is .003 inches. Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158628 Share on other sites More sharing options...
[RP...] Posted Wednesday at 04:21 PM Author Share Posted Wednesday at 04:21 PM this cone feature has circle scans every 1.5° going both ways with the 3.0mm probe. all the scans are in one feature. Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158634 Share on other sites More sharing options...
[Ri...] Posted 5 hours ago Share Posted 5 hours ago Any chance you are using an L probe? Link to comment https://qualityforum.zeiss.com/topic/27916-what-would-be-causing-2-scans-in-the-same-area-to-differ-in-height/#findComment-158656 Share on other sites More sharing options...
