Red sphere
Are they the giant red spheres like this?  If so, let me know what you find.  I am training a new programmer and a lot of his programs have these giant red spheres.  I'm sure its an easy fix, but I haven't spent any time looking into it.  I told him I'd show him how to fix it and maybe someone can save me some time.
https://qualityforum.zeiss.com/topic/27918-red-sphere/#findComment-158560
FYI, Wojciech was correct.  It was CAD>Setting>Strategy> Display probing as probe feature.  That, and I had change the colors tab back to yellow too.
Here's what's weird to me:  There's almost no way this guy knew how to change that.  At the same time,
 is having the same problem.  Isn't it a bit weird that two people, completely not connected, had the same problem at the same time?
https://qualityforum.zeiss.com/topic/27918-red-sphere/#findComment-158562
I actually like this feature. The spheres are the size of your probe (if it's calibrated), so you immediately know if the probe is going to fit in tight spaces. The transparency setting is messed up - I can't get it to work properly. Most of the time they are just solid color. Used to work great when they introduced it.
https://qualityforum.zeiss.com/topic/27918-red-sphere/#findComment-158584
