[Pa...] Posted Tuesday at 06:33 PM Share Posted Tuesday at 06:33 PM While running one of my programs while the base alignment is being measured the calypso crashes. It started doing it maybe ones every couple parts but now it does it every part. I've have yet to run into a issue like this. What could be casing it? Link to comment https://qualityforum.zeiss.com/topic/27920-zeiss-crashing/ Share on other sites More sharing options...
[Ze...] Posted Tuesday at 07:43 PM Share Posted Tuesday at 07:43 PM Need more information. What do you mean it crashes? Does the software crash? Does the probe crash into the part? Are you running a manual alignment first, a stored CNC alignment, etc? Do you have repeatable fixturing? Is it in the correct location? Link to comment https://qualityforum.zeiss.com/topic/27920-zeiss-crashing/#findComment-158572 Share on other sites More sharing options...
[Ma...] Posted Tuesday at 07:51 PM Share Posted Tuesday at 07:51 PM I once got into situation, where old, very used program was suddenly calling BA can not be calculated. I was forced to change whole BA and SA to new method. I was trying everything, because that program wasn't changed and even was running for a while after changing from 6.6 to 7.8 BA or SA was done by free RPS points on model. Link to comment https://qualityforum.zeiss.com/topic/27920-zeiss-crashing/#findComment-158574 Share on other sites More sharing options...
[Pa...] Posted 1 hour ago Author Share Posted 1 hour ago Please sign in to view this username. I start with start alignment and while its going the base alignment the soft ware crashes. I Actually did what Please sign in to view this username. suggested and its seem to have fix the issue. Link to comment https://qualityforum.zeiss.com/topic/27920-zeiss-crashing/#findComment-158702 Share on other sites More sharing options...
