AI- in Zeiss Calypso
Hello everyone.
I have been assigned a task to look into the feasibility of using Claude AI to generate Macros in Solid Works for CAD model PMI and "Somehow" get Calypso to generate inspection program.
Please share your thoughts if you heard anyone else is trying to make this happen.
Best regards
Levan
https://qualityforum.zeiss.com/topic/27922-ai-in-zeiss-calypso/
I am surprised, that nobody from your company is not affraid to paste models and drawings into AI.
I don't think it will ever create correct file structure, but i think it would guide you to place correct paths, points and so on just like cookbook, but fitted into exact model.
My only connection to AI is through helping in programming parsers for undocumented files and just now for repairing my old lcd tv ( after measurements i ended up with using hot air to correct bga on cpu )
https://qualityforum.zeiss.com/topic/27922-ai-in-zeiss-calypso/#findComment-158578
I think it should be coming soon as Zeiss Inspect now has some. I would say dont wait.
 I am also working on a program to take 2d dwg and cad, and have AI generate PMI which will create 90%+ of my program.
 Where I work we have our own AI and its awesome so it helps, so far in early stages working pretty good.
Good luck !
https://qualityforum.zeiss.com/topic/27922-ai-in-zeiss-calypso/#findComment-158586
On the innovation days in Berlin they showed a software that took a drawing and generated a model and PMI, and with that Calypso generated a program.
It looked promising, and can most likely reduce time for programming. Not complete replace a cmm guy, that will never happen with complex parts. But it could be a great aid.
  • Awesome! 1
https://qualityforum.zeiss.com/topic/27922-ai-in-zeiss-calypso/#findComment-158602
